marius Posted May 20, 2006 Report Posted May 20, 2006 Download File:post-5076-1148162188.vi Hello, I have created this VI in LabVIEW 7.1 and I cannot read the array written on file. can anyone help me please? thanks, Marius Quote
jpdrolet Posted May 21, 2006 Report Posted May 21, 2006 Download File:post-5076-1148162188.viHello, I have created this VI in LabVIEW 7.1 and I cannot read the array written on file. can anyone help me please? thanks, Marius On the Write File node wire the input "Write Header" to True Quote
marius Posted May 21, 2006 Author Report Posted May 21, 2006 Download File:post-5076-1148182891.vi On the Write File node wire the input "Write Header" to True I just got back to this forum because it happened to find a solution. Probably is not the only one. I've found your recommendation and I thank you very much. I am planning to pay attention to this aspect in the future. I attach this solution it here. I have tested with several save and load and it seems reliable. Do you find it reliable and robust? any weakness? The attached file is just a trial for a bigger subprogram that I need to write with an array of 10 rows, each row being a similar cluster of 23 various variables with variable content from row to row. Any comment will be very appreciated. thanks, Marius Quote
