write and read an array of clusters
Download File:post-5076-1148182891.vi
  jpdrolet said:
On the Write File node wire the input "Write Header" to True
I just got back to this forum because it happened to find a solution. Probably is not the only one.
I've found your recommendation and I thank you very much. I am planning to pay attention to this aspect in the future.
I attach this solution it here. I have tested with several save and load and it seems reliable. Do you find it reliable and robust? any weakness?
The attached file is just a trial for a bigger subprogram that I need to write with an array of 10 rows, each row being a similar cluster of 23 various variables with variable content from row to row.
Any comment will be very appreciated.
thanks,
Marius
