brent99 Posted May 23, 2006 Report Posted May 23, 2006 As far as I can tell, this doesn't seem to work programmatically. I have no idea if this is a new problem or not. Quote
Yair Posted May 23, 2006 Report Posted May 23, 2006 Can you create a specific example showing whatever you think the problem is? I remember testing the remote FP methods and properties in 7.0 and they worked fine. I assume they were tested for 8 as well. Quote
Aitor Solar Posted June 7, 2006 Report Posted June 7, 2006 They work in 7.1, but not in 8. Saludos, Aitor Quote
brent99 Posted June 13, 2006 Author Report Posted June 13, 2006 They work in 7.1, but not in 8.Saludos, Aitor Thanks for confirming that! Makes sense. Probably something got mucked up when they changed the name between the versions. I imagine it'd be easy to fix it that's the case. Still, without the ability to assign a particular client to the server, it has limited utility to knock somebody off with the lock control. I was originally interested in this control because running the code in debug version, the clients don't always gain control on the first request click. This seems to work fine from an executable, though. Quote
