Siemens S7 PLC+labview 7.0
Mize
  Mize said:
I think I need OPC server/client software but would anybody have more specific information about the subject?
Mize,
You've got a lot of options and aren't necessarily limited to using OPC. A lot may depend on how many euros you have to spend.
A web search (example here) will bring up dozens of OPC servers for Siemens S7 and there are quite a few that make use of the "HMI Adapter" cable
  • 1 month later...
First of all, thank you dswaine for you reply. It provided help.
Since my first post things have evolved to a point where I can give simple boolean orders to the PLC, which then inserts pre-defined attributes to the ACH550-01 motor/frequency converter. The motor runs and there is a OPC server opening the PLC registry to LabVIEW via datasocket connection.
Now I am in a need of advice on how to write hex-values in labVIEW to let say address: PQW 258. I think I need something like slider which converts the values from 0-100 % to 0-4000hex and then writes this value to OPC-address. Would anyone have an example on how to do this?
-Mize
  • 1 month later...
Hello all,
I thought to drop back to report about my success. It was pretty hard to find information about the subject
but with a lot of patience and different approaches I managed to get the damn thing working.
What I used was software toolbox TOP opc-server to open the PLC registry to labview and then it was more
about creating the actual logic program with STEPS7. Used SFC14 ja SFC15-functions and data blocks to bypass
the 4 byte continuous limitation of PLC.
It has been a steep learning curve but I have enjoyed programming with labVIEW.
-Mize
  Mize said:
Hello all,
-Mize
Hello Mize
In my industry, at first we "solved" this problem problem by installing Step7(or Wincc and just declare every tag on a dummy project) on the same computer as labview, or RSLinx if the PLC is Allen Bradley. In every case we need a license from Siemens or AB, something that was out of question, especially for Siemens, because they are TOO expensive, even for a single license. Then we found out about IBHSoftec, which besides the OPC server provides some nice tools and cables, AND S5 for Windows.
Hope i helped.
