meocop Posted May 24, 2006 Report Posted May 24, 2006 Hello, I am trying to write selective data to a file. By "selective", I mean I want the users to turn a on/off switch to only save the data that they like. So I figured if I put my data through a Case loop and wire an On/Off button to it, that will do the trick. Attached is my vi. I have two problems with it. 1. Some how, even I put everything in a while loop, the execution stops after 1 iteration. Can anyone help explain? 2. For my Case loop, I hope that the False case would not give any data, but that's not the case. False case gives "0". Is there a better way to do this? Your respons is much appreciated. MC Download File:post-4960-1148504903.vi Quote
popsekel Posted May 25, 2006 Report Posted May 25, 2006 MC, You are not far from the basic premise of what you are trying to do... 1. To get your loop to run for more than 1 iteration right-click on the boolean (wired to the stop indicator) and select "change to control". Now when you run the program the loop will iterate until the control is pressed to True. 2. Instead of casing out the data value itself, I would recommned incorporating the file write operation into the case structure. This way the file will only be written when the boolean is ON (True). This should get you started. 3. Might I also suggest adding a small loop delay to control how fast your loop iterates (slow it down to allow your PC to handle other processes). Hope this helps... ES Hello,I am trying to write selective data to a file. By "selective", I mean I want the users to turn a on/off switch to only save the data that they like. So I figured if I put my data through a Case loop and wire an On/Off button to it, that will do the trick. Attached is my vi. I have two problems with it. 1. Some how, even I put everything in a while loop, the execution stops after 1 iteration. Can anyone help explain? 2. For my Case loop, I hope that the False case would not give any data, but that's not the case. False case gives "0". Is there a better way to do this? Your respons is much appreciated. MC Quote
meocop Posted May 25, 2006 Author Report Posted May 25, 2006 MC,You are not far from the basic premise of what you are trying to do... 1. To get your loop to run for more than 1 iteration right-click on the boolean (wired to the stop indicator) and select "change to control". Now when you run the program the loop will iterate until the control is pressed to True. 2. Instead of casing out the data value itself, I would recommned incorporating the file write operation into the case structure. This way the file will only be written when the boolean is ON (True). This should get you started. 3. Might I also suggest adding a small loop delay to control how fast your loop iterates (slow it down to allow your PC to handle other processes). Hope this helps... ES That's awsome. It worked now. Thanks for your help ES. MC Quote
