Richard Khoo Posted May 25, 2006 Report Posted May 25, 2006 Hi, I am using Pixelink 6.6MP camera with IIDC driver in MAX. I was allowed to choose FORMAT 7 which is scalable image size option in MAX. However, the image I got in screen was shown as the file attached. Multiple images. Is anyone of you know what is the problem? Is it the driver problem or is the camera itself? I was told in the manual that I can choose 4 different formats. However, only 2 formats available in MAX, does anyone of you know why? Is there anywhere I can configure? Please advise. Thanks! Quote
Chris Davis Posted May 25, 2006 Report Posted May 25, 2006 Hi, I am using Pixelink 6.6MP camera with IIDC driver in MAX. I was allowed to choose FORMAT 7 which is scalable image size option in MAX. However, the image I got in screen was shown as the file attached. Multiple images. Is anyone of you know what is the problem? Is it the driver problem or is the camera itself? I was told in the manual that I can choose 4 different formats. However, only 2 formats available in MAX, does anyone of you know why? Is there anywhere I can configure? Please advise. Thanks! I've run into issues before with Pixelink cameras and NI 1394. You might check with Pixelink and see if they have seen this problem. I was working with a A741 (1.3 MegaPixels 8 or 10 bit) which had very little information in MAX in terms of camera modes, and they had a firmware update which added more capabilities (camera modes) for MAX. I'm not saying its not an NI problem, but you might check with Pixelink to see if they have run into this problem before. That camera has been on the market for the last year or two, so I'm betting they at least know of the problem. Quote
pallen Posted May 25, 2006 Report Posted May 25, 2006 Are you using the NI drivers or PixelLink's drivers? We had problems with our Fire-I cameras using the supplied drivers. Quote
Richard Khoo Posted May 29, 2006 Author Report Posted May 29, 2006 Hi pallen, I'm using the NI IIDC driver. I assume I am not allowed to use Pixelink's driver if I would like to use IMAQ in Labview. Do you have any thoughts? Quote
