For loop won't fill array
Hi
I'm a first timer and my experience with LabVIEW is limited (although growing fast everyday)
I built this little VI where I am reading HEX values (bytes) from one file. I format the data and pass it to a FOR loop where Hexadecimal String to Number puts every byte into a unsigned integer array using an Auto-Indexed Tunnel. I then repeat the process for a second file. This completes my VI
When I run the VI for the 1st time (read from 2 files), it works perfectly fine. But when I run it for a 2nd time (read for the 3rd and 4th time), the integer array is filled with 0's (wired an indicator). Only way to get around this is to fully close the VI and then re-open it.
Should i re-initialize the tunnel every time? If so, how? Could it be that my array is 'big' i.e. 7200 items? Hopefully I'm clear enough
Thanks for your help
Fred
I wish you could upload an image of your diagram.
...or even attach a VI that you've already created so we could suggest modifications...
Fred,
It couldn't be the array size, 7200 items is not at all big! I've filled arrays to the point that I ran into RAM limitations, so lets say 300MB of free space, 8 bytes per array element, comes to about 37,000,000 array elements. Sure, the computer gets a bit testy in these cases, refuses to respond, etc, etc..., but never at a mere 7200!
As Mike and Crelf said, post what you have and someone here ought to see the problem.
-Pete Liiva
Thanks for the help. My VI sends register and memory content to an IC using SPI.
Here is a screenshot of the 2nd sequence of my VI. The sequence right after is the exact same but I load a different file. The 1st, 4th and 5th sequences send hardcoded data to the SPI programmer no arrays involved. That's it. Run the whole thing once, you're fine. Try to do it again, array is filled with zeroes.
the file being loaded in the beginning is of the following structure
0xXX, 0xXX, 0xXX, .... where XX is a HEX representation of a byte.
Thanks again
Just to confirm - your file structure is:
0xXX<space><comma>0xXX<space><comma>0xXX<space><comma> ...
where XX are your HEX characters? (it helps to attached an actual example file to clear up these misunderstandings).
The problem is occurring because you are not initializing the shift register that is wired to the offset input of the Hexadecimal String to Number function in your For Loop. Whatever index value was the last value written to that shift register will be the first value given the next time the VI runs. So this will probably be a large offset value that is at the end of the file, thus resulting in no hexadecimal value found, thus resulting in a default value (zero) being output from the function.
I think if you wire a zero constant to initialize the shift register the problem will be solved.
-D
-D
Thank you so much Darren!
I knew it probably was something very simple. It now works exactly how I want it to.
Thanks again
Fred
