Karl Rony Posted May 31, 2006 Report Share Posted May 31, 2006 Recently, two threads asked for assistance on how to store complicated data in a database. One person wanted to store images. Another person wanted to store an array of data. I keep waiting and hoping for a solution because I've tried to do both with the NI DB toolkit / ODBC / Microsoft Access, but I failed. I couldn't figure out how to get the NI DB toolkit to use a memo field as a blob and not a string. I started tinkering with Microsoft ADO, but I had to put it aside. I don't care how big the database gets nor do I expect to search for values in an array or cluster. I'll have other fields that I can use to narrow my search. I don't want data stored in files scattered in the Microsoft Windows file system. I'm afraid the data will get lost or moved in the central file server. I want the information contained in a single database. Eventually, I hope to implement replication. When I want to retrieve data, I'll use the other fields for a query search. Once I find the record I want, I'll use a LabVIEW program to recreate the exact environment that I had when I saved the record. I'm even more encouraged by the free, express databases such as SQL Server Express 2005 Oracle 10g Express IBM DB2 Express Thanks in advance for any assistance in leading us in the right direction. Maybe one day, I'll solve the problem with ADO and post my solution here. Quote Link to comment
Michael Aivaliotis Posted May 31, 2006 Report Share Posted May 31, 2006 Maybe one day, I'll solve the problem with ADO and post my solution here.is it ok if I beat you to it? Quote Link to comment
snooper Posted June 7, 2006 Report Share Posted June 7, 2006 Have a look at www.tm-solutions.eu and the database Toolkit. Makes database communication and datatypes a lot easier. Supports SQL server and MsAccess. With kind regards, Arnoud Recently, two threads asked for assistance on how to store complicated data in a database. One person wanted to store images. Another person wanted to store an array of data. I keep waiting and hoping for a solution because I've tried to do both with the NI DB toolkit / ODBC / Microsoft Access, but I failed. I couldn't figure out how to get the NI DB toolkit to use a memo field as a blob and not a string. I started tinkering with Microsoft ADO, but I had to put it aside.I don't care how big the database gets nor do I expect to search for values in an array or cluster. I'll have other fields that I can use to narrow my search. I don't want data stored in files scattered in the Microsoft Windows file system. I'm afraid the data will get lost or moved in the central file server. I want the information contained in a single database. Eventually, I hope to implement replication. When I want to retrieve data, I'll use the other fields for a query search. Once I find the record I want, I'll use a LabVIEW program to recreate the exact environment that I had when I saved the record. I'm even more encouraged by the free, express databases such as SQL Server Express 2005 Oracle 10g Express IBM DB2 Express Thanks in advance for any assistance in leading us in the right direction. Maybe one day, I'll solve the problem with ADO and post my solution here. Quote Link to comment
