Connection using IP adress
Hi
I have to connect a plastic injection machine using LabVIEW, this machine has an ethernet connection and I know that it's correctly connect to the computer but I don't succed in find the machine using LabVIEW. I tryed with datasocket and with server explorer but maybe there is something special to do. If somebody has an idea it can be nice.
Thanks
belou21
  Aitor Solar said:
Maybe I'm being too obvious, but does the ping work?
Saludos,
Aitor
Yes I tryed and the ping works at 100%, that's why I sayed that I'm sure that the machine is well connect.
  Aitor Solar said:
OK, have you tried "TCP Open Connection"? What kind of error do you get?
Saludos,
Aitor
And do you know what port number it is listening to? That is as important in establishing a connection as knowing the IP address.
-Pete Liiva
Hi
we told me that it's better to don't use TCP open function and I prefer use OPC server and data socket read/write function.
I order a OPC sever software for my machine and if somebody knows how program it with Labview it can be nice!
Thanks
