vronto31 Posted June 8, 2006 Report Posted June 8, 2006 HI I have tried a block diagram from a NI site to run a firewire camera however after making the blockdiagram.I get the following error on running the program. "NI IMAQ IEEE 1394:(Hex 0xBFF68008)feature not present in the camera. I am not sure what thi smean and what is the problem. I am using a firewire camera by "IMAGING SOURCE" the link is as follows http://zone.ni.com/devzone/conceptd.nsf/we...&node=201714_US the camera is working as the camera is giving image in vision assistant. thanks Download File:post-5265-1149769630.vi Quote
Mike Ashe Posted June 8, 2006 Report Posted June 8, 2006 Did you check to see if the Triggering Modes are the same between the VI and Vision Assistant? Did you try to acquire images / video in MAX? Lastly, did you try some of the builtin example VIs that ship with IMAQ Vision? Quote
vronto31 Posted June 8, 2006 Author Report Posted June 8, 2006 HI I have tried a block diagram from a NI site to run a firewire camera however after making the blockdiagram.I get the following error on running the program. "NI IMAQ IEEE 1394:(Hex 0xBFF68008)feature not present in the camera. I am not sure what thi smean and what is the problem. I am using a firewire camera by "IMAGING SOURCE" the link is as follows http://zone.ni.com/devzone/conceptd.nsf/we...&node=201714_US the camera is working as the camera is giving image in vision assistant. thanks Download File:post-5265-1149770755.vi Quote
vronto31 Posted June 9, 2006 Author Report Posted June 9, 2006 Hi Thanks I have seen it and finally my Vi is working . regards Quote
