wouda Posted October 6, 2006 Report Posted October 6, 2006 Hi, Make sure that the USB camera name for the "IMAQ USB Init.vi" matches the name from the "IMAQ USB Enumerate Cameras.vi". If I wire the same name everything works fine. With a different name I get the "Filter could not be found" error. I hope this helps Quote
Ton Plomp Posted October 7, 2006 Report Posted October 7, 2006 Hi Firime, If you are using a non-english OS, you should take the steps in this forum. Ton PS NI forums is better on this stuff Quote
