if-than structure
Hi all,
I am still novice in Labview, but i like it :D
I would like to create a vi which can make the following:
I have got a control and one string indicator. if you write 1 into the control than a function will be executed in a sequence and write a string into the indicator, if you write 2 than another function should be executed, if you write 3 than a third function ...and so on if you write a number into the control which has no sequence than an error message should be indicated into the string indicator!!
how can i build this thing? I attached my weak idea in a picture (of course it is not work)
if you have any idea please share with me!
thanks for the help in advance :worship:
post-5296-1150712272.jpg?width=400
