JDave Posted June 19, 2006 Report Posted June 19, 2006 I remember some thread about dealing with the different application references found in LV 8. Projects create their own, etc. I searched and searched. :headbang: I have a filename, and I want to open the VI reference but this does not work if the VI is in a different app ref. Can someone point me in the right direction? David Quote
LAVA 1.0 Content Posted June 21, 2006 Report Posted June 21, 2006 I think if you just first open an application reference and then open a VI reference (wire the application reference as an input). Each application propably have a different TCP port on the local machine so you can access different applications if you know the TCP port. There may be an easier way I'm not aware of. Quote
JDave Posted June 22, 2006 Author Report Posted June 22, 2006 I finally found the thread I was looking for here. Quote
