Cpow Posted June 20, 2006 Report Posted June 20, 2006 Hello everyone, I am new to these forums and also new to LabView. I am currently running LabView 8.0 for a class that I am currently attending. I think LabView is a great program and I have a lot of potential on it; however, I am having a really difficult time trying to program something. My teacher didnt exactly teach us how to do anything on LabView, he basically gave us the program and 3 hours to learn it. For an assignment I have to prove convololution on two discrete signals using the built in convolution VI in LabView. I completed this part because it is a relatively simple task. Now I have to Write my own convolution VI and use it to convolute the same two signals. Now I am a complete novice when it comes to LabView and programming in general. I have no idea how to begin this nevermind actually starting to write a code for convolution. I'm honestly not sure if anyone would know what im talking about but i see a lot of intelligent posts on this forum and i figure perhaps someone could help me out. If this seems easy to anyone could you possibly help me get started? Im terrible with programming and with LabView, I just need a little help. Thank You -Chris Quote
crelf Posted June 20, 2006 Report Posted June 20, 2006 My teacher didnt exactly teach us how to do anything on LabView, he basically gave us the program and 3 hours to learn it Nice! Post what you've already done with an explination and we'll try to help. (the coffee was actually excellent this morning - Panera cappacino - mmmmmmmmmm ) Quote
Cpow Posted June 26, 2006 Author Report Posted June 26, 2006 Well basically what i have to do is create my own convolution VI and use it. Its probably really simple but i just dont know how to get started. I attached my work so far which includes me using the built in convolution VI in labVIEW 8.0 on 2 simple signals. Basically what convolution does is it takes the second signal, flips it around the x axis, then moves it to the right. Whenever the signals are overlapping it multiplies them together. It's hard to explain i know. This is a really simple explanation of how convolution works. Now all i have to do is create my own convolution VI, but i really dont know where to get started. Im looking into it and ill update whenever i get any idea of how to do it. Thanks, p.s. I also dont know how to attach thumbnails :/ .. How do i do that? -Chris Download File:post-5351-1151280875.vi Quote
Kurt Friday Posted June 26, 2006 Report Posted June 26, 2006 Well basically what i have to do is create my own convolution VI and use it. Its probably really simple but i just dont know how to get started.I attached my work so far which includes me using the built in convolution VI in labVIEW 8.0 on 2 simple signals. Basically what convolution does is it takes the second signal, flips it around the x axis, then moves it to the right. Whenever the signals are overlapping it multiplies them together. It's hard to explain i know. This is a really simple explanation of how convolution works. Now all i have to do is create my own convolution VI, but i really dont know where to get started. Im looking into it and ill update whenever i get any idea of how to do it. Thanks, p.s. I also dont know how to attach thumbnails :/ .. How do i do that? -Chris Hi Chris First, I admire how you have asked for help and you have had a really good shot at solving your problem. I can provide a little hint here. You are using express vi's, however you can convert an express vi into a regular vi by simply right clicking on the express vi and selecting "Open Front Panel", the express vi will then be converted, take a look inside, you will then see subSignalProcessin.vi, take a look in there that will help you. Also if you want to attach an image into your post simply attach the image file and then you will be given a reference which you can insert in your post. Good luck with it. Quote
Guest terminator Posted June 26, 2006 Report Posted June 26, 2006 If you can describe it, you can implement it (although it might take a while to find the right vis to do it). I suggest starting your search under the array palette. In particular there is a "Reverse 1D array" vi that should be very useful. Well basically what i have to do is create my own convolution VI and use it. Its probably really simple but i just dont know how to get started.I attached my work so far which includes me using the built in convolution VI in labVIEW 8.0 on 2 simple signals. Basically what convolution does is it takes the second signal, flips it around the x axis, then moves it to the right. Whenever the signals are overlapping it multiplies them together. It's hard to explain i know. This is a really simple explanation of how convolution works. Now all i have to do is create my own convolution VI, but i really dont know where to get started. Im looking into it and ill update whenever i get any idea of how to do it. Thanks, p.s. I also dont know how to attach thumbnails :/ .. How do i do that? -Chris Quote
Cpow Posted June 26, 2006 Author Report Posted June 26, 2006 Wow thank you so much.. I can understand this much better now .. ill keep going and see what i can do. thanks alot guys! -Chris Quote
Gary Rubin Posted June 26, 2006 Report Posted June 26, 2006 Convolution can also be implemented MUCH faster in the frequency domain, using FFTs. See here. Quote
