James P. Martin Posted June 26, 2006 Report Posted June 26, 2006 Hi, Could anybody please tell me that I have to switch on/off relay for which I am using simlpe DAQmx write to channel, and the data I am writing is a Boolean which itself is a combination of various digital inputs I am acquiring, but I want to know that as I am using sequence structue so after switching on the relay , at any time if that Boolean becomes false(based on the status of Digital inputs) , will it have a effect on the relay(will it be off simultaneously, if I dont clear the task at the switcing On relay) OR I have to write again at the channel to make it switch off using that Boolean(combination of Digital inputs). With regards James Quote
