converting array data to .bmp file
Hi everyone, I am totally new to Labview and need some help here.
I have generated an array using LabView and want to convert the array into a .bmp file. In my array, the element can only hold a value of '0' or '1'.
I want to convert this array full of '0' or '1' into a .bmp file with black and white pixels. I wonder if this is possible?
Thanks.
Do you have the NI-Vision Toolkit installed?
I am not sure if I have what you have mentioned. However, when I looked under my NI tree, I see this... National Instruments > Vision.
Is this what you are talking about?
Pardon my ignorance.
LabVIEW ships with a handful of basic vision functions under the "Vision and Motion" functions palette, but you can also get an add-on toolkit called the NI Vision Development Module. You can convert integer arrays to bitmaps, so all you need to do is create a low bit width (8 bit) image space (IMAQ_Create) and then convert your Booleans into integers (0/255), populate them into the image (IMAQ_ArrayToImage) and then save it our to a bitmap (IMAQ Write Bitmap File):
post-181-1151940299.png?width=400
Download File:post-181-1151940289.vi
Download File:post-181-1151940390.zip
This can also be done with the standard picture VIs (which ship with most versions of LV) and can be found (at least before LV 8.0) in the Graphics & Sound palette.
You basically need to use Flatten Pixmap and wire the result into Write BMP file. You will also need to convert your array into a boolean array, which you can do by wiring it into a Not Equal to Zero? node.
post-1431-1151940891.png?width=400
Yep - that'll work too :D
Thanks - yen and crelf. It works.
I just want to confirm, when I used Yen's method, my output file is not black-and-white, instead, it is made up of 2 colors. The .bmp file can be red with blue or yellow with green or green with white or etc.... And everytime I run the program, it will get different combinations.
I wonder if anyone is seeing this too? Is there anyway I can do so that I will always get black and white ONLY in my .bmp file?
Appreciate your help/assistance/comments.
If you read the help for the function, you will see that the colors of the boolean array are determined by the first 2 elements of the Colors[] array. All you need to do is drop a couple of color box constants (from the Numeric>>Constants palette) in a constant array and set them to be white and black and wire that constant in as the colors.
I think my sample can help you, and you can define its"size" to get bmp's pixel.
Download File:post-4703-1152021249.vi
Thanks Yen. It took me the whole day to get familiar with simple array functions and trying to control the colors[] array. Afterall I am a 3-day old Labview user. Your method works. Many thanks.
Thanks to Cool-LV for helping too!
