jsharlan Posted July 10, 2006 Report Share Posted July 10, 2006 I'm using 'Get Control Value {Variant__ogtk}' to save the values of DAQmx controls on a Front Panel to a config file. When I read back the values from the file and use 'Set Control Value {Variant}__ogtk' to set the control values, I'm getting an 'ERROR 1' and the controls are not updated. Is there a work around for this? Quote Link to comment
Ton Plomp Posted July 10, 2006 Report Share Posted July 10, 2006 I'm using 'Get Control Value {Variant__ogtk}' to save the values of DAQmx controls on a Front Panel to a config file. When I read back the values from the file and use 'Set Control Value {Variant}__ogtk' to set the control values, I'm getting an 'ERROR 1' and the controls are not updated. Is there a work around for this? Use strings they are automatically converted into the right format! Perhaps you should make the controls strings and convert them insde the VI! Ton Quote Link to comment
