Touchy timed loops
Has anyone had problems with timed loops causing crashes? I get really bad crashes - the reboot kind. If I disable the timed loop or replace it with a regular loop with a time delay, then everything is fine so I know it's the timed loop. This has happened in several different situations so it's hard to give an example. It happens with hardly anything in the loop or more complicated code inside it. I'd just replace the timed loop with a regular loop, but it's handy to be able to stop the timed loop when using parallel loops.
George
