config data registry
I'm opening (and yes, closing) references to several INI files using LabViews config file VIs. Even though I'm closing those files, I see by using the Profiler that Config Data Registry.vi just continues to grow and grow. Besides closing the file after accessing it, what can I do to get it to release memory?
Even though you're handling files appropriately, the memory used by the VI can be related to other tings - are you appending data to a FP control or shift register? Can you post your code so we can have a look at it?
