andalusian Posted July 20, 2006 Report Posted July 20, 2006 Hi, I'm using the Labview Webcam Library 1.4.1 ( www.cs.unc.edu/~parente/labview/index.shtml ); along with two logitech webcam 5000 pro webcams. I can get one webcam to work however the other one doesn't get detected in Labview. My hypothesis is that since both of the webcams use the same driver, the issue might be occuring, and perhaps if I had two dis-similar webcams with different libraries, I might be able to change which driver is being utilized. Am I right or is there a quick fix to the problem ? In theory there ought to be a software based fix, considering the logitech capture software can switch between the two webcams. BTW: I'm not interested in having both of them work simulatanously ( although it would be nice ), just plain stopping one webcam, and enabling the other one is what I would like to have, and this at the moment doesn't seem to work. Anyone have a solution ? Best Regards, Andalusian Quote
andalusian Posted July 21, 2006 Author Report Posted July 21, 2006 Hi,I'm using the Labview Webcam Library 1.4.1 ( www.cs.unc.edu/~parente/labview/index.shtml ); along with two logitech webcam 5000 pro webcams. I can get one webcam to work however the other one doesn't get detected in Labview. My hypothesis is that since both of the webcams use the same driver, the issue might be occuring, and perhaps if I had two dis-similar webcams with different libraries, I might be able to change which driver is being utilized. Am I right or is there a quick fix to the problem ? In theory there ought to be a software based fix, considering the logitech capture software can switch between the two webcams. BTW: I'm not interested in having both of them work simulatanously ( although it would be nice ), just plain stopping one webcam, and enabling the other one is what I would like to have, and this at the moment doesn't seem to work. Anyone have a solution ? Best Regards, Andalusian NVM, It works with the newer drivers from NI. Andalusian Quote
crelf Posted July 21, 2006 Report Posted July 21, 2006 NVM, It works with the newer drivers from NI.Andalusian I agree - drop Pete's drivers (they were only a bit of an experiment anyway) and use these ones instead. Quote
