Label of Formula Node
The label of a Formula Node is not associated to it's BD object. While, For, and sequence structures will reposition the label when the associated object is resized on the block diagram. The Formula Node label just 'hangs out' wherever it is placed. In certain cases, the label can even appear to be part of the formula after a resize :blink:
I was documenting and refactoring some old code, and noticed that this problem exists.
Minor irritation, checked and this existed in LV 7.1 as well...
That's what I get for touching old code! :nono:
