osvaldo Posted July 25, 2006 Report Posted July 25, 2006 Hello, I'm writing a program to manipulate backups... To save disk space, I wish I use the zip file format to compress files... So I have tried to use the ZLIB Library from the OpenG package... but... when I drag the ZLIB Extract File on my diagram, Labview show to me the search file message window to find the ZLIB Time Info VI... Anyone knows where I can found it? Thanks! Quote
Jim Kring Posted July 25, 2006 Report Posted July 25, 2006 osvaldo said: Hello, I'm writing a program to manipulate backups... To save disk space, I wish I use the zip file format to compress files... So I have tried to use the ZLIB Library from the OpenG package... but... when I drag the ZLIB Extract File on my diagram, Labview show to me the search file message window to find the ZLIB Time Info VI... Anyone knows where I can found it? Thanks! This is a known issue with the latest version. Try installing version 2.2.0, as I think this one is working fine. Also, you might want to install VI Package Manager while you're at it. Quote
osvaldo Posted July 26, 2006 Author Report Posted July 26, 2006 Jim Kring said: This is a known issue with the latest version. Try installing version 2.2.0, as I think this one is working fine. Also, you might want to install VI Package Manager while you're at it. Ok! The version I currently installed is the 2.0-1... This seems work fine! :thumbup: Many thanks! :worship: Quote
