stuckinlabview Posted July 27, 2006 Report Posted July 27, 2006 I am unable to use rs232 through labview if someone could help or refer to me some good tutrial I,ll be very thankful to you Quote
Tom Limerkens Posted July 27, 2006 Report Posted July 27, 2006 Check the examples supplied with LabVIEW : Help >> Find Examples >> Hardware Input and output >> Serial Start from there. Tom Quote
RagingGoblin Posted July 27, 2006 Report Posted July 27, 2006 This is what I use. (SIAM is my device) Download File:post-4151-1154008114.vi Download File:post-4151-1154008143.vi Download File:post-4151-1154008158.vi Quote
stuckinlabview Posted July 28, 2006 Author Report Posted July 28, 2006 stuckinlabview said: I am unable to use rs232 through labviewif someone could help or refer to me some good tutrial I,ll be very thankful to you thnx Man :thumbup: Quote
stuckinlabview Posted August 1, 2006 Author Report Posted August 1, 2006 1) in VISA Configure Serial Port (Instr).vi->Basic Serial Write and Read.vi Error -1073807342 occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi->Basic Serial Write and Read.vi This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input. I am having this error while running the basic serial read and write VI please help me Quote
cbr Posted July 28, 2007 Report Posted July 28, 2007 QUOTE(stuckinlabview @ Aug 1 2006, 07:40 AM) Quote 1) in VISA Configure Serial Port (Instr).vi->Basic Serial Write and Read.viError -1073807342 occurred at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi->Basic Serial Write and Read.vi This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input. I am having this error while running the basic serial read and write VI please help me I have been getting this same error code when trying to communicate with any serail port on the computer. All the ports are correctly set up and detected no problem by windows device manager. But when I open the labview measurement & automation application, I can't see any serial ports. In fact the devices and interfaces tab will not display at all. I am currently using an evaluation version of labview 8.2. Previously I was using labview 7.1 with no problems at all. Quote
Grampa_of_Oliva_n_Eden Posted July 28, 2007 Report Posted July 28, 2007 QUOTE(cbr @ Jul 27 2007, 10:42 AM) Quote ... But when I open the labview measurement & automation application, I can't see any serial ports. In fact the devices and interfaces tab will not display at all.... Did you attempt a "Refresh" ? If that does not do it, MAX may need repaired or re-installed. Ben Quote
