lalala Posted August 14, 2006 Report Posted August 14, 2006 Sorry if this is a silly question, i'm a newbie with labview If I have a file which contains a set of data, how do i draw a xy graph of it? Any help will be much appreciated. Thanks! Quote
Anders Björk Posted August 14, 2006 Report Posted August 14, 2006 Sorry if this is a silly question, i'm a newbie with labview If I have a file which contains a set of data, how do i draw a xy graph of it? Any help will be much appreciated. Thanks! Hint drag some different graph indicators on the front panel and look at the help! Or search for a tutorial as "Labview for dummies" Anders Quote
Louis Manfredi Posted August 14, 2006 Report Posted August 14, 2006 Hi Lalala: Welcome to LAVA! Several ways of plotting XY data. Easiest way to get started might be to place the Express XY graph from "Graph" subpallette of the "Controls" palette onto the front panel. You can use the express vi as-is or you can open it up (and in particular its sub-vi) and see how the data is prepared for plotting so you can do the job on your own. There are also a number of examples of XY plotting that ship with LabView, you can navigate to them through the help system--- a powerful friend of the LabView newbie :thumbup: Hope this helps, Louis Quote
mross Posted August 14, 2006 Report Posted August 14, 2006 It would depend entirely on how the data is formated in the file. If you could share that.... Quote
