LAVA 1.0 Content Posted August 25, 2006 Report Posted August 25, 2006 I encounter the following quite frustrating problem. I've created a class hierarchy of three classes. I'd like to make a copy of these classes. So I add a new folder to the project explorer, add all the classes to this folder, convert it to library and save everything. To test if this library works, I run en example that uses the classes and which I also included in the library. Well, LabVIEW crashes and the project gets corrupted. Detailed information below. System is Win XP SP2 + LabVIEW 8.2. To repeat the bug do the following: - create an empty dir called Tree - extract the Tree_002.zip to this directory - open Tree.lvproj - click My Computer on project explorer and select New Folder - Name the folder Tree - Move all 3 classes and the Tree Example.vi to this new folder - Right click the Tree folder and select convert to library - Save the library as Tree.lvlib inside Tree directory (you created in step 1.) - select Save All - Open Tree Example.vi - Run it LabVIEW crashes and the project gets corrupted. Posted to NI with ref num #8959-P3E602 Download File:post-4014-1156528264.zip Quote
