Chris Davis Posted August 29, 2006 Report Posted August 29, 2006 The attached VI attempts to get the size of a file using two methods. The first is the File / Directory info primitive, the second is the Get File Size primitive. Both should return the same number. When attempting to use this method on files bigger than 2 Gb the File / Directory primitive will not work because it returns an I32 for size. I haven't filed this with NI yet, so no CAR has been created, I wanted to list it here first to let someone else confirm my bug finding. BTW, you must supply your own 2Gb + file... Download File:post-2547-1156870998.vi Quote
Jacemdom Posted August 29, 2006 Report Posted August 29, 2006 The attached VI attempts to get the size of a file using two methods. The first is the File / Directory info primitive, the second is the Get File Size primitive. Both should return the same number. When attempting to use this method on files bigger than 2 Gb the File / Directory primitive will not work because it returns an I32 for size. I haven't filed this with NI yet, so no CAR has been created, I wanted to list it here first to let someone else confirm my bug finding. BTW, you must supply your own 2Gb + file... Verified. Is it a bug or a feature? I would say a feature that became a bug! Quote
Chris Davis Posted September 6, 2006 Author Report Posted September 6, 2006 Well, I was wrong about the error being produced with files >2gb, its actually wrong when files are greater than 4gb. I've included screen shots of this error in LV8.0.1 and LV8.2. I've also submitted this to NI and will post a CAR when I get one. Whats weird is that LV8.2 and LV8.0.1 produce different results with the same large (14gb) file. Chris Quote
Chris Davis Posted September 8, 2006 Author Report Posted September 8, 2006 This bug has been confirmed by NI. CAR: 417BKAGI. Note, this bug exists in LV 8 and 8.2. I'm going to cross post to the 8.2 bug list for completeness. Quote
Chris Davis Posted September 8, 2006 Author Report Posted September 8, 2006 Bug found in LV8.0.1 and 8.2. See post here. Quote
