LAVA 1.0 Content Posted September 4, 2006 Report Posted September 4, 2006 LabVIEW links to wrong context help. If there are many VIs with the same short name but different long name, wrong context help may appear. The image below describes the problem. Quote
LAVA 1.0 Content Posted September 6, 2006 Author Report Posted September 6, 2006 LabVIEW links to wrong context help. If there are many VIs with the same short name but different long name, wrong context help may appear. The image below describes the problem. To clarify, the context help that appears in the image is that of LabVIEW internal function Create Mask.vi whereas the context help that should appear would be that of a class method Create Mask.vi. Quote
