Project chek out
Salut.
Am i missing something, or is it really not possible to check out a project from the menu-->tools-->Source control? Is it going to be implemented in the next version?
Yes, in the project window you have to select the files you want to check in / out and right click OR use the Tools\Source Control\Check In (or Out)
This is usefull for checking in a lot of files.
Ton
Ton
I want want to check out the project file...i noticed that if i modify the project by creating a new VI, it ask if i want to check out the projetc...so i believe my problem is solved, even if my question remains unanswered...
You have to select the
Project:******.lvproj
line, this will give you the reaction you want!
Ton
