Jacemdom Posted September 6, 2006 Report Share Posted September 6, 2006 Salut. Am i missing something, or is it really not possible to check out a project from the menu-->tools-->Source control? Is it going to be implemented in the next version? Quote Link to comment
Ton Plomp Posted September 6, 2006 Report Share Posted September 6, 2006 Am i missing something, Yes, in the project window you have to select the files you want to check in / out and right click OR use the Tools\Source Control\Check In (or Out) This is usefull for checking in a lot of files. Ton Quote Link to comment
Jacemdom Posted September 6, 2006 Author Report Share Posted September 6, 2006 Yes, in the project window you have to select the files you want to check in / out and right click OR use the Tools\Source Control\Check In (or Out)This is usefull for checking in a lot of files. Ton I want want to check out the project file...i noticed that if i modify the project by creating a new VI, it ask if i want to check out the projetc...so i believe my problem is solved, even if my question remains unanswered... Quote Link to comment
Ton Plomp Posted September 6, 2006 Report Share Posted September 6, 2006 I want want to check out the project file...i noticed that if i modify the project by creating a new VI, it ask if i want to check out the projetc...so i believe my problem is solved, even if my question remains unanswered... You have to select the Project:******.lvproj line, this will give you the reaction you want! Ton Quote Link to comment
Jacemdom Posted September 6, 2006 Author Report Share Posted September 6, 2006 You have to select the Project:******.lvproj line, this will give you the reaction you want! Ton :thumbup: Quote Link to comment
