Datasocket read using PSP and LV 8.2
I have two applications that communicate by one VI publishing a shared variable and the second application reads the variable using a datasocket read with the PSP protocol. This used to work fine under LV 8.0.1. Now that I've switched to 8.2 it doesn't work anymore and gives me the following error:
Error 1181 occurred at DataSocket Read in Time Lapse.vi
Possible reason(s): LabVIEW: Protocol not recognized by LabVIEW.
NI so far hasn't come up with a solution. Has anybody else had trouble with this?
George
  • 1 year later...
Hi
I just read your post so i don't know if you solved this problem or not,
If you are using datasocket on a computer that does not have labview installed or just had a run- time engine, you have to install the datasocket yourself (the installer is on the DSC cd in the Products folder).
Hope it helps...
Hi
Hope it helps...
