Cascading Ring Control
I have a UI that uses a ring control. The problem is that usability decreases as the number of items increases. It would be nice if I could categorize the options kind of like the Windows Start menu. Has anyone done something like this?
Like a custom right-click menu? You can do those in 8.
Yes, like a right-click menu, but as a left click on a ring control.
Mike Holmstrom did a custom OO-based right click menu a couple of years ago - I'm sure that could be modified pretty easily to work the way you want, although it needs the Endevo OO toolkit to work.
  • 3 years later...
Use a mousedown? filter event, and switch the first for the second button, this will trigger a 'Shortcut menu activation event'.
Ton
