help Labview XML-->string
Hello everyone
I'm a beginner in Labview and i have a problem of the conversion XML-->string :headbang:
In fact, i have a file XML that i consider as a table of strings, i have to get the information stocked in the last line of this file, just before </LVData>. The longer of the XML file isn't fixed. Could you help me with this problem? Thanks a lot :worship:
Welcome to LAVA!
I don't know much about xml, but I guess your file looks something like this:
<?xml version='1.0' standalone='yes' ?>
<LVData>
<Version>8.2</Version>
<Array>
<Name></Name>
<Dimsize>0</Dimsize>
<String>
<Name></Name>
<Val></Val>
</String>
</Array>
Is this the line you want?
</LVData>
So, to get your line of data, can't you just search for </LVData> and take the line before that. Example:
post-2740-1159875732.png?width=400
Of course, this can as always be done more efficient, but this works.
Thanks for your answer, thols
I have a problem with your solution : the function "Research an expression" waits for a string but my file XML is a table of strings, so the types of data aren't compatible...
However, i found another solution after lots of tests :
File XML --> Function "length of a table" --> length -1 --> Function "To Index a table" with index 'length-1' for the last line, the output of "To Index a table" is the data that i have to save...
Thanks again :thumbup:
