Control the Specturm analyzer through ethernet interface
Right now,I want to use Labview to control the Specturm analyzer through the ethernet interface.....
Does anyone know how to do this?
resourse in hand:
labview 8.2
Advantest specturm analyzer U3700 series
A good place to start is the National Instruments Instrument Device Driver Network. Your device isn't listed there, but there are a few with model numbers close to yours, and with a little adjustment to the VISA drivers you should be able to get something up and running. Another possible resource is the manyfacturer's website: http://www.advantest.com
hi crelf,thanks for your reply.
now,i have configed it in the MAX.
the advantest specturm analyzer is not supported by the VXI-11 bus.
for i have configed it in the max,i want to communicated it by using the VISA VIs
i programed a simple VI for the communication,but it can't work
when i run it,it showed err -1073807343
can you help me again.
I guess it is a VISA error, just open Help->Explain error... and paste your code into the error code field.
Error -1073807343 occurred at an unidentified location
Possible reason(s):
VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
Seems like you are using a bad address?
/J
Possible reason(s):
/J
HI JFM,thanks for your reply.
just like this.
what can i do to solve this problem?
my instrument is Advantest specturm analyzer U3700 Series U3751
my software is labview professional 7.1
visa 4.0 full version
i set my instrument ip 192.168.0.1 socket number:5025 (referenced by the instrument manual)
my pc ip:192.168.0.2 connected by a cable with RJ45
my instrument is not supported by the VXI-11 bus so in the MAX i selected the RAW network socket when i configed
it.
Are you using an ethernet hub or a crosscable?
otherwise your computer and spectrum analyzer are talking on the same wire and both listening on the other wires.
and that means no communication
just like this.
i am using a crosscable......
what can i do ?
