[CR] Truncate Path Xcontrol
index.php?automodule=downloads&req=display&code=sst&id=29
File Name: Truncate Path Xcontrol
File Submitter: tcplomp
File Submitted: 8 Oct 2006
File Updated: 11 Oct 2006
File Category: XControls
This XControl is originated from this discussion.
It will truncate a path to fit inside a string:
Besides basic funtionality it has the following properties:
  • Truncated string (Read only property that will return the truncated string)
  • Button Visible (Read/Write, this property will show/hide the browse button)
  • Browse properties (Read/Write, this property will set/get the browse options)
Methods:
  • Truncate Path (this method uses the VIs to truncate a path to a string)
For the developer it has the following advantages:
  • Set the browse options with a dialog similar to the native browse options dialog
  • Browse for a path
  • Show/Hide browse button
Known issues:
No drag and drop
Bounds of indicator/control include invisible browse button
Acknowledgements:
Uses code by Dave Thomson:Display Long Path.vi
post-2399-1160478800.png?width=400
