i2dx Posted October 26, 2006 Report Posted October 26, 2006 File Name: Frontpanel Tool File Submitter: i2dx File Submitted: 25 Oct 2006 File Updated: 26 Oct 2006 File Category: LabVIEW Development Environment IBB Frontpanel Tool V 2.0.4 Copyright Quote
Michael Aivaliotis Posted October 26, 2006 Report Posted October 26, 2006 One thing I noticed was that one of your dialog boxes had text in German. It's fed by a constant on the diagram. Quote
i2dx Posted October 26, 2006 Author Report Posted October 26, 2006 Michael_Aivaliotis said: One thing I noticed was that one of your dialog boxes had text in German. It's fed by a constant on the diagram. ok, thank you. I will fix that with the next release, which is allready in work and which will have 2 new features: 1: you can select, if you want to go down the entire hierarchy or not 2: you can select, whether you want to use the last changed VI (-hierarchy) or the "Menu Call VI" by default EDIT: V 2.0.5 is availiable, the dialog is now in english and I added the 2 features Quote
