just registered
mann3r
Hello Dear member,
I am just new in this forum since i have search the net for some LabVIEW and Labwindows forums, which i could get some information specially on building application for manufacturing use. Hope to get in touch Sorry for my introduction.
Welcome to the LAVA forums.
I suggest that you also check out the forums at NI's site.
One reason is that they also have a CVI board.
another is that there are a lot more people there, so if you're asking a simple question, you're more likely to get a quick answer.
Another suggestion is to try searching for the information you're looking for before posting any questions. You should also look for some tutorials, as there are a few of those around.
Hi, and welcome aboard!
There is lots of stuff applicable to manufacturing here on the forum and a lot of us work (or have worked) in that area.
To start, might I suggest you read: How To Use the LAVA Website
Then you might want to tell us a little more about the specifics of what you do with LabVIEW and what type of manufacturing problems you are trying to solve. The more specific you can be the more response you usually get here.
Good luck :thumbup:
