Continue in Time Loop
Q^Q
I have a time loop, the interval is 1s.
In one iteration, after running 0.5s, an event occur.
I want break this iteration immediately, and jump to the next iteration.
Can I do this?
Hi, i'm new on this forum but i think i can help on your problem :P
I think you can use time-out option of Event Structure.
You can see an example on the picture attached.
Best regards :)
Good!
This structure helps me solve the problem.
Thank you!
Can I do this?
If you are using a RT Target, the way with the Event-structure doesn't work. :nono:
Therefore you can do this also with the Timed-loop.
=> configure the timed loop to 1000ms iteration time
=> give your timed loop a meaningful name
=> you can abort the timed loop with the stop Timed Loop structure...
post-1396-1164348444.jpg?width=400
