Q^Q Posted November 22, 2006 Report Posted November 22, 2006 I have a time loop, the interval is 1s. In one iteration, after running 0.5s, an event occur. I want break this iteration immediately, and jump to the next iteration. Can I do this? Quote
French LVer Posted November 22, 2006 Report Posted November 22, 2006 Hi, i'm new on this forum but i think i can help on your problem I think you can use time-out option of Event Structure. You can see an example on the picture attached. Best regards Quote
Q^Q Posted November 23, 2006 Author Report Posted November 23, 2006 French LVer said: Hi, i'm new on this forum but i think i can help on your problem I think you can use time-out option of Event Structure. You can see an example on the picture attached. Best regards Good! This structure helps me solve the problem. Thank you! Quote
martin@aerodynamics Posted November 24, 2006 Report Posted November 24, 2006 Q^Q said: I have a time loop, the interval is 1s. In one iteration, after running 0.5s, an event occur. I want break this iteration immediately, and jump to the next iteration. Can I do this? If you are using a RT Target, the way with the Event-structure doesn't work. Therefore you can do this also with the Timed-loop. => configure the timed loop to 1000ms iteration time => give your timed loop a meaningful name => you can abort the timed loop with the stop Timed Loop structure... Quote
