how can calibrated DAQ ?
alameer
I have DAQ 6024 E when used to read a analog signal from Function Generator ,the result Inaccurate .
How can calibrated so that the results valid?
What do you mean by "inaccurate"? Is the signal offset? Is there a nonlinearity? Are you sure the inaccuracy is in the DAQ card? Could the issue be the Signal Generator? My guess would be the latter... Open up MAX, click on "MAX Help" and then do a search for "Self Calibration".
