reading HDF 4.x
SHO
  SHO said:
right now i was in a project using HDF 4.x as an input so...
is there any chance that i could read HDF 4.x in LV?
(sory for the english btw :oops: )
HDF5 is not downwards compatible with HDF5 so you cannot use HDF5 libraries directly. However you can convert HDF4 files to HDF5 files either using a command line tool or by calling a DLL library. For HDF5 there are sever libraries. I've implemented HDF5 1.8.0 alpha for LabVIEW. If you are interested in this package, you can send me a personal message and we can add you to the beta program. The package very strictly follows HDF5 C API and even has a reference manual for LabVIEW.
thx for the offer of the package, but the thing that i really need is the LabVIEW directly read the HDF4 file :( is it possible :blink: ?
for the command line tool i've found it at http://www.hdfgroup.org, but it needs zlib1.dll to run :(
(again sorry for my bad english :headbang: )
You can call the HDF4 DLL directly from LabVIEW, I don't kwow if there is any workaround.
Well zlib shouldn't be a problem as you can download it for free from http://www.zlib.net/ .
what's the name for the dll file, is it hdf.dll?
yups i got it... going to test it tomorrow cuz in my time its very late... :D
o btw thx a lot jimi :)
