telurkuda Posted December 1, 2006 Report Posted December 1, 2006 is there any of u know how to save array of numeric and string data together on one spreadsheet file, please send me any solution, trick, or example code. regards. telurkuda. Quote
Falevoz Y. Posted December 1, 2006 Report Posted December 1, 2006 I'd probably do something like that By! Yann Quote
telurkuda Posted December 4, 2006 Author Report Posted December 4, 2006 hi dear yann.. your example is done well. thanks. now i try to extract certain row of the table of 2D array. i still struggling with this.. any idea?? regards. telur Quote
Falevoz Y. Posted December 7, 2006 Report Posted December 7, 2006 Hi! With this program you'll get the element of the second column for witch the element of the fist column is equal to 5. Elements of the first column have to be unique. If they're not, you'll get the first one... With this program you'll get an array with all the raw for witch the element of the first column is between 3 and 5. Elements of the first column don't have to be unique. You can change the test to answer to your needs. If the result of the test is false, you just have to transmit the array from the shift register to the shift register. By Yann Quote
