Addressing single bit
dingin
hi everyone
I am working with datasocket and OPC server. The data comes in 2 forms,
a 32 bit float and single bit.
I can read and send the 32 bit tag by using the numeric
data type single precision, but as for the single bit, the smallest numeric
data type LV has is 1 byte.
The OPC explorer program allows me to address the entire byte or each bit
which represent valve on/off states. In LabView I just want to be able
to address a particular bit, not the entire byte.
Any suggestions would be greatly appreciated!
As far as I know the smallest addressable memory element in C++ is one byte i.e. 8-bits. If your OPC interface uses something like 1 bit variables, they very probably are really 8-bit variables of which only 1-bit is used. Can you provide the defenition of the OPC method API you are trying to pass bits and how these bits are defined in the API.
  dingin said:
I am working with datasocket and OPC server. ...
In LabView I just want to be able to address a particular bit, not the entire byte.
Apologies if I'm missing something but ...
If you're using frontpanel Datasocket connections: have you tried just linking a boolean/switch to a particular bit?
If you're using the Datasocket VIs: have you tried DataSocket Write Boolean.vi or DataSocket Read Boolean.vi (from ... \LabVIEW xx\vi.lib\platform\dataskt.llb).
A 1-bit number simply means its value can be 0 or 1. And luckily enough, a rose is a rose... If you use any of the int type of data and send a 0 or 1 your code should work. Reads and Writes to that value shouldn't require any 'bit banging' because the value is just 0 or 1 (there is nothing to manipulate).
:worship:
I tried each of the suggested methods, and they all work!
-Using front Panel Datasocket connection to OPC,
1) write a True or False to boolean control (V3.1,3.2 in my example)
2) send 0 or 1 to I8 unsigned byte (V4.1,4.2, in my example)
3) convert 8 element 1D boolean array (with boolean array to number function) and pass to I8 unsigned byte.
-In the block diagram
3)Use a datasocket write boolean subVi from dataskt.llb (V6 in my example).
I had tried the boolean and I8 in the front panel DS connection before without success.
My OPC server must have hosed up somehow on that occasion.
Thanks everyone!
post-7081-1165068957.png?width=400
post-7081-1165068986.png?width=400
