Guenther Posted December 13, 2006 Report Posted December 13, 2006 Hi guys, I'm pretty much stuck with a problem. I have to call a .net dll from labview. So I do all this stuff with the constructor note, call the function with an invoke note and close the reference again. On my development machine it works like a charm, also when I compile my application the .exe works fine. However, when I transfer my application to another PC, I'm getting error 2 (memory full) immediately after calling the constructor node. Needless to say that it's not really a memory problem. The dll and my app are in the same paths on my development machine and the other PC. We asked the supplier of the dll for a little program the test the dll and that works fine on both PCs. So it has something to do with the way I call the dll in LV. Any ideas? Thanks a lot, Guenther Quote
Ton Plomp Posted December 13, 2006 Report Posted December 13, 2006 Maybe the dll is not registered on the target? Try running regsrv32.exe with the dll name as parameter Ton Quote
Guenther Posted December 13, 2006 Author Report Posted December 13, 2006 Maybe the dll is not registered on the target?Try running regsrv32.exe with the dll name as parameter Ton We do have an installation routine for the dll, and somewhere in the process a message pops up that the dll has been registered. I tried regsvr32 anyway and I got a message that the dll is loaded but the entry point could not be found. Don't know what to make of that. However, regsvr32 delivers identical messages on both PCs, so at least there's no difference here. Guenther Quote
Ton Plomp Posted December 13, 2006 Report Posted December 13, 2006 Hi Guenther, strange... I think you should try contacting Bryan Tyler of NI (lycangeek) He is the .net master of them! Ton Quote
lycangeek Posted December 14, 2006 Report Posted December 14, 2006 Well, the regsvr32 is for ActiveX/COM, so that shouldn't be an issue. It could be that the .NET assemblies you are using are expecting to be in the GAC, but from your comments, it doesn't sound like that's the case. The .NET assemblies (DLLs) should be in the same directory as the EXE or in the /data or /bin subdirectory. Let's get some information.... 1. What version of LabVIEW? 2. What versions of .NET are installed on your dev machine and the other PC? 3. What version of .NET was the .NET assembly you are using built against? I've got some other possibilities, but let's start with this. Brian Quote
Guenther Posted December 15, 2006 Author Report Posted December 15, 2006 2. What versions of .NET are installed on your dev machine and the other PC? Looks like that was the problem, the other PC had an older version of .net framework installed. With an update it works now. Should have checked that. Thanks Brian and Ton for your inputs! :beer: Guenther Quote
