video proccesing
hello genios of LabVIEW.
I have a litle problem:
I make an aplication that track people in a region. I'm adquiring the video whit a webcam (creation). The aplication is runing but I need to see the diferent stages of the video proccesing. I try to put diferents image displays to see the video(for example one at the RGB image stage and another at the binarization stage, but the image look like all the procces were view in one image display (all the stage at the same time) .
I hope you can help me ..............
thanks.
I forgotten, here is the aplication:
Hello,
What toolkit do you use for video in LabVIEW?
It's possible to display video and processed video in separate windows, or in the same video window in picture in picture mode, for example, or in the same video window showing the selected dispay mode (raw video or processed video). It's all possible with correct toolkit.
By the way, didn't see your application that you mentioned.
Irene
I am not sure if you pointed to the wrong link above??
To attach a file, please click on "Browse..." to select your file, then press "UPLOAD" at bottom when you write your post. Just scroll down and you will see.
Irene
  • 3 months later...
  • 1 year later...
