How to read the state of a digital output?
patufet_99
Hello,
When using standard multifunction NI-DAQ cards (as the M series), is there a way to know the status of a digital output?
When executing a VI, at initialisation I would need to know the actual status of the digital outputs without having to changing it.
Thanks for your help.
Hello,
Hello it's quite easy, have a look at following example:
post-1396-1166519411.png?width=400
So just use DAQmx Read to read an Digital Output.
But be careful if you invert a DO Task, and you read the DO Task with DAQmx Read, the result is not inverted!!
I don't now if this is a bug or if this has to be. In my opinion it's probably a bug...
Because if I configure a Task as Inverted, I expect also the read to be inverted (if I use the Task Name and don't read direct a DO over it's DO number (port etc.)
Hello Martin,
Thanks for your reply. As you noted is quite easy! I was just disturbed by the fact that digital ports can be used as inputs as well as outputs.
Merry Christmas and thanks again.
Regards.
Patufet
