Verifying a header
I have a header I am adding to the top of a file.
I am adding data and appending this file.
I want to be able to verify that the header does not get corrupted.
I am using the search and replace string VI or the Match pattern VI.
I was wondering if anyone has approached this a different way.
Hi Bob:
Depending on what your header looks like, there might be an easier way.
You Can wire strings, like just about anything else, to the equals operator.
(Also, if the header is a bunch of strings, you can compare string arrays, and right click on the comparison to choose "compare aggregates"-- giving a true value only if both arrays are identical.)
Best Regards, Louis
