encryption Posted December 31, 2006 Report Posted December 31, 2006 I am working on a labview mobile 5.0 application using labview 8.2 and I need to be able to submit a URL to a web server and then retrieve the data in a string. I plan on using match pattern on the retrieved data after I have received the HTML data. Thanks for any help you can provide! Thanks, Nick Powers Quote
encryption Posted January 1, 2007 Author Report Posted January 1, 2007 In standard labview I could use the http control but I need to learn how to do this with the basic TCP tools provide with the PDA module. Thanks! Nick Powers I am working on a labview mobile 5.0 application using labview 8.2 and I need to be able to submit a URL to a web server and then retrieve the data in a string. I plan on using match pattern on the retrieved data after I have received the HTML data.Thanks for any help you can provide! Thanks, Nick Powers Quote
crelf Posted January 1, 2007 Report Posted January 1, 2007 In standard labview I could use the http control but I need to learn how to do this with the basic TCP tools provide with the PDA module. Hi Nick, and welcome to LAVA! What you're asking for isn't really a LabVIEW question per se, but more a tcp / HTTP question. LabVIEW can perform whatever tcp messaging you like, so try a google on terms like "get" "html" "tcp" etc... Quote
Jim Kring Posted January 1, 2007 Report Posted January 1, 2007 I am working on a labview mobile 5.0 application using labview 8.2 and I need to be able to submit a URL to a web server and then retrieve the data in a string. I plan on using match pattern on the retrieved data after I have received the HTML data. Nick, There is an unreleased http library in the OpenG CVS repository which uses TCP-IP to perform an HTTP GET. Info on how to do a CVS checkout: http://sourceforge.net/cvs/?group_id=52435 Browse CVS Repository (ViewCVS): http://opengtoolkit.cvs.sourceforge.net/op.../http/http.llb/ The http library depends on some other OpenG libraries, so you should install VI Package Manager in order to download+install the OpenG libraries. -Jim Quote
