BadLuckMan Posted January 10, 2007 Report Posted January 10, 2007 Hello All, I've encountered a rather special problem by writing measuremnt data to disk. I've got an array [sGL] of about 28,8MB size which I write to disk with the Write File.vi. (LV 7.1) This worked very well for a while. But unfortunately I now often receive the error code 6 from the Write File.vi. The file is created but has 0Kb when the error occurs. I have made sure that there is enough disk space and that the path is correctly formated. I'm using W2k SP4 and it is a 124GB partition with about 50% free disk space. It only happens on one machine which has a hardware RAID1 (Adaptec Controller) configured. So maybe it's not really a LabView problem, but has anyone encountered such a problem before ? Thanks for any help and suggestions, Ralf. Quote
