Error -1073807298 occurred at VISA Write
pockey
I'm developing a serial communication program with LabVIEW 8.20. There is a USB to RS232 cable connected to a testing board.
As topic shows, when I write commands to the board, there will be error shown:
Error -1073807298 occurred at VISA Write in ML2427Tester.vi
Possible reason(s):
VISA: (Hex 0xBFFF003E) Could not perform operation because of I/O error.
The program could run OK after I click the "Continue" button. Anyone is aware of such error??
If the error is not so important, how could I ignore it for proper operation of my program?
A picture of the block diagram could be seen here:
ML2724Tester -- Error at VISA Write
Thanks!
Download File:post-6631-1168917470.vi
Hi pockey,
I haven't looked in detail, but you should host the image at LAVA, because now the portal is messed up because of your picture (see here), or just post a link to the picture.
I will look in detail later, but am in a hurry.
Ton
Hi Pockey,
thanks, (maybe it's just me)
You should have a look at the error cluster, pass it on between several parts of your code:
post-2399-1168925063.png?width=400
The wait with error is an OpenG VI downloadable with VIPM
other q's:
are the default serial settings OK for your device? (look at that error out as well)
Have you tried communicating with the devicde from MAX?
EDIT:
Having looked at your code I advice some redesign.
Use less states the (Reset/Begin/Status/Help) states are almost the same. Use a seperate Read and Write state. In your read state you need some timeout (10-50 ms) or so.
Ton
Well, it seems the problem is with the USB to RS232 cable.
I tried another connector and there's no error now.
Well, how to get rid of the error if I use that USB to RS232 cable since I know the error is with the cable not the program?
Have you fully installed the usb-rs232 device?
We saw that we could write, but not read with a default usb-rs232 device.
Ton
  pockey said:
Strange!
I could read but not write with the cable...
The driver of the cable is not recognised by Windows, and it causes blue screen sometimes.
There are many I2C to serial converters (especially multiple port devices) that have similar problems with VISA. Some or all functions then don't work (properly).
I have very good experience with Prolific drivers, all devices with Prolific drivers always work.
Joris
  • 9 years later...
I'm developing one TMC instrument and I get this error when -
my TMC instrument is connected to Hub and Hub to pc. If I unplug and replug the USB connection for hub, I get this error. Hub is getting power from USB as well as AC-DC power adapter. If I reset the hub completely, i.e if I'm unplugging the power cord and unplugging usb connection to hub both, then plug back both, everything works fine. What could be issue in this case? I'm using Keysight IO Libraries for my development.
Thanks.
