ned Posted January 23, 2007 Report Share Posted January 23, 2007 Try this: place a case structure on a block diagram. Put a "VISA GPIB Control REN" node inside it. Right click on the "mode" terminal and choose "Create -> Constant." The constant appears on top of the case structure, rather than inside it. If you drag the constant away from the case structure, it appears to have a valid wire, but doesn't. Quote Link to comment
